115 speedo??
Old May 7, 2003 | 02:02 PM
burnemonm1's Avatar
115 speedo??
Stupid Question... I have a 94 Z28, what do I need to do to get white face gauges or the glow gauges if my speedo only goes up to 115 and it says the only ones I can order are for a 150 speedo??
thanx for the help
Old May 7, 2003 | 02:05 PM
madwolf's Avatar
Just get yourself a 150 speedo and do them both while you're at it. You should be able to pick a used one up for $50 or so.
Old May 7, 2003 | 06:09 PM
BigRich's Avatar
and PCM re-programming cuz you also have the 115mph speed limiter for H-rated tires
Old May 7, 2003 | 09:01 PM
burnemonm1's Avatar
I got a hypertech
Old May 7, 2003 | 09:15 PM
hsyr's Avatar
You will need the 150mph guage cluster. No other way around it. I just did it myself.
Old May 7, 2003 | 09:38 PM
SaxRulez's Avatar
do you have to reprogram anything when you change the gauge cluster?
Old May 7, 2003 | 09:46 PM
madwolf's Avatar
You don't have to, but you will still have the 118 MPH limiter.
Old May 8, 2003 | 12:34 PM
burnemonm1's Avatar
I found white faces for 6 cylinder and the pic looks identical to my cluster... will these work? and why do I need the 150 cluster???
Old May 8, 2003 | 12:41 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
maybe you guys can help me out... i also have the 115 mph speedo and speed limiter... ( i now have Y rated tires, so that governor's gotta go...) but i want a speedo that will show the full potential of my car... with a couple future mods and my 2:73's im fairly certain she will be capable of 180mph by next year... so i want a 180mph speedo... like the in the 95 vipers... anyone heard of anything that would be easy to do in my formula?
Old May 8, 2003 | 12:46 PM
burnemonm1's Avatar
180? where in the hell do you plan on doing this??? why don't you make a custon gauge cluster with auto-meters my buddy did that in his vette and it looks sweet
Old May 8, 2003 | 12:47 PM
frmula1's Avatar
where do i plan on going that fast you mean?
Old May 8, 2003 | 12:48 PM
madwolf's Avatar
There are no 180 mph speedo for our cars. Granatelli made some 200 mph ones but those were for 97+ cars.
Either way, it won't be easy and it won't be cheap, but you can however go with a 150 MPH cluster which will work great without having to do anything else other than the cluster swap. And it's like $50, so it's a great mod.
As for burnemonm1's question... you don't have to swap to a 150 cluster (although I don't see why someone wouldn't want to do that) but I don't think the V6 overlays will work. I beleive the V8 low MPH cluster goes up to 110 and the V6 one goes up to 120, so it won't be accurate. But if it looks 100% identical, then it should work. Maybe they also make them for the V8 110 cluster, did you ask?
Old May 8, 2003 | 12:53 PM
burnemonm1's Avatar
no not yet but I found the 110's on a website which is what my speedo goes up to not 115 I think that is in like the rs sorry if I confused anyone.
and where do you plan on going 180 frmula1??
Old May 8, 2003 | 12:56 PM
madwolf's Avatar
OK, maybe RS ones go up to 115, but the 3.4 V6 is 120 for sure.
Old May 8, 2003 | 12:57 PM
frmula1's Avatar
Limerock, here in CT....
its a raceway.... kinda curvasious...(sp?) but its got a straight away thats like 4/5th's of a mile i believe... and figuring you can come out of turn 5 at 45-50mph if your good and you need to be down to a max. of 90 for turn 6 i think i can get er up to 170 or so in the straight away (that is after i get some high end power, like a cam)
