Installing Airbag in Rear spring?
Old May 5, 2003 | 10:26 PM
darkangel95's Avatar
I just purchased an airbag to install in my right rear spring and I was just wondering if anyone has any links to installation instructions on one. Or if anyone on here has any tips please feel free to tell me.
Old May 6, 2003 | 08:38 AM
ttt
Old May 6, 2003 | 08:44 AM
FastZinTennessee's Avatar
If no one can give you an answer here, you might try the drag racing forum
John
Old May 6, 2003 | 09:32 AM
Gripenfelter's Avatar
I put mine in last fall.
Took about 1 hr.
Disconnect the lower shock mount.
Raise the car in the air until all the weight is off the spring.
Squeeze all the air out of the airbag so its flat enough to fit between one of the coils.
Place the airbag base plate at the bottom of the coil and insert the airbag through one of the coils with the nib pointing down.
Make sure you plug the nib before instering it to make sure it doesn't inflate on you.
After the airbag is inside the coil, unplug the nib, run your line, lower the car and connect the shock.
Old May 6, 2003 | 10:05 AM
Sorry guys I should have put this one in the drag racing forum. I didn't even think about that last night. But I just knew that this forum is the one with the most traffic.
But thanks alot for the info Gripenfelter...
Old May 6, 2003 | 10:10 AM
magius231's Avatar
hey Grip, did you notice a decent difference doing this? I know this is a popular upgrade for the Buick GN guys, some of which are running really nice 60' times with nothing more than a bag in both springs...
Old May 6, 2003 | 06:09 PM
Nah it's ok, I just thought you might get an answer faster over there Guess I was wrong hehe
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
wytblur
Mar 2, 2003 03:40 PM
