Jacking Points???
Old May 5, 2003 | 01:00 PM
Raider Z28's Avatar
Jacking Points???
Where do you place the floor jack when jacking the car? Where do you place your jackstands?
Old May 5, 2003 | 02:26 PM
Laymaster's Avatar
it depends on what you're working on.
I use the A-Frames in the front, or the engine cross member will work as well.
Placing them on the subframe connectors works as well..
And in the rear, I place it on the rear subframes or the LCA's....
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
