How hard to R&R Slave Cylinder/MC
Has anyone installed a new hydrulic system including the slave cylinder, master cylinder, reservoir?
I'm considering having my car towed from the shop and doing this myself...they want $450 for this or $1000 for this AND a clutch...is there anything tricky with this? I don't think it requires pulling the tranny or anything...
Sean
Sean
Changing the master cylander and the slave does NOT require pulling the tranmission. Changing the clutch does. If they told you that you should change them while the trans is out cause its easier, they ripping you off. Not only that if they charge a lot for the install on the master and slave their trying to sap mony out of you. This is my opinion. The guys at the shop tried to tell me i needed to change my master cyclander in order to save a costly repair later, i told them how it was.
