abs inop, no idea???
Old May 7, 2003 | 11:41 AM
ledfootz28's Avatar
my abs inop went on and i changed the rear brake fluid then it went off.a week later its back on.i changed the rear rotors and pads like a month ago and the light went on like two weeks later and thats when i changed the fluid.i dont hear or sense any prob with the brakes,they work fine.i dont think it could be a sensor or connection because when i bled the brakes it did go off for a couple of weeks.any ideas on what i should do?
Old May 7, 2003 | 11:45 AM
ledfootz28's Avatar
when i bled the brakes i only did the rear brakes and forgot to start on the passenger side brake.i started on the drivers side.and i only bled the rear brakes b/c i put rear rotors and pads on.could dirty fluid just have gone through the system??maybe when i pushed the pistons on the calipers in it pushed in dirty fluid.the light is coming on like every couple weeks and im only driving barely 20-40 miles a week
Old May 7, 2003 | 04:58 PM
ttuz's Avatar
sally
Mine did the same thing. My third brake light was out. Replaced the bulb and it was fixed. This is common apparently.
asilomar244
Jul 12, 2015 05:53 AM
pologreen97z
May 18, 2015 02:17 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
Black Sunshine/ 00SS
Aug 31, 2002 02:26 PM
