Is my tranny going bad?
Old May 7, 2003 | 01:04 PM
mind buRn's Avatar
Just got a '97 Trans Am and whenever I am accelerating from a stop and I get on it the rev limiter kicks in. The engine can be hot or cold, doesn't matter. It usually happens around 3 - 4k rpm. I have been told by one dealer that the car should do this and by another that my tranny is going bad. Anyone have any input on this?
Old May 7, 2003 | 01:25 PM
TedH's Avatar
From your very general description it sounds like the tranny is slipping. You just got th car? Does it have one of those 30 day warranties?
Old May 7, 2003 | 01:27 PM
mortal z28's Avatar
my car did that a long time ago.. it would get to a certain RPM and just start sputtering and cutting out.. turned out it was a bad coil wire.. when i replaced that i also replaced all plugs and wires.. ran good as new
Old May 7, 2003 | 01:28 PM
TedH's Avatar
misfiring at higher rpms if often a bad coil or coil wire. Hitting the rev limiter sounds more like the tranny. Perhaps do a fluid change and see what happens but once it slips there isn't much you can do except rebuild or replace.
Old May 7, 2003 | 01:29 PM
mortal z28's Avatar
by the way your car should *NOT* do that.. whoever told you that needs to be selling go-peds
Old May 7, 2003 | 02:00 PM
Silver Z28's Avatar
Nah man, I don't wanna buy a lemon go-ped
Hobbyguy
May 26, 2015 02:15 PM
dylan1303
May 22, 2015 12:24 PM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
