help me with my tranny pleaseeeeeeeeeeeee
Old May 7, 2003 | 07:54 PM
ONELOUDKAR's Avatar
Angry help me with my tranny pleaseeeeeeeeeeeee
ok, at WOT AT AROUND 4500-5000 rpm's my car feels like it skips to the rev limiter which is set at 6600rpm's. Does anyone elses do that? Could it be the silonoid or the acumilator? it will not shift the 2-3 shift, the 1-2 is fine though. please help me out here guys
thanks
-Mike
Old May 7, 2003 | 08:24 PM
funina91ss's Avatar
sounds like burnt clutches time for a rebuild
Old May 7, 2003 | 09:51 PM
ONELOUDKAR's Avatar
man, this would be my 3rd transmission in the car. It has 120k miles on it as well. anyone else had this many trannies with an older car, mine is a 95
Old May 8, 2003 | 12:04 AM
Donny O's Avatar
sounds like you have 2 problems.....won't shift to 3rd and cutting out. will it shift to 3rd when you are NOT WOT? does it cut out around 4500-5000RPM in every gear or jsut as your reaching the top of 2nd?
my car had both of these problems at the same time. one was a shift silonoid in the tranny(sometimes it worked fine and others it jsut gave me 1 and 2nd gear) and the cutting out was bad plug wires.....they jsut both happened within a week of each other.
Old May 8, 2003 | 12:15 AM
ttopz28's Avatar
I had the 'wont shift 2-3' [if I let off a little it would shift] before and I had the transmission serviced and it fixed it. ie. Change tranny fluid, flush lines, change filters. Im having the problem with the shifting again, so I guess i'm going to get it serviced soon again.
Old May 8, 2003 | 07:54 AM
ONELOUDKAR's Avatar
Yea, it shifts fine when i am not at WOT. It does not cut out of gear everytime either. It is just at WOT, the 2-3 shift. Car runs and shifts fine during regular driving. I just dropped it off at the tranny shop. He had said something about a silonoid also. Was
that a $$$$ item or cheap? It is weird, under WOT after the 1-2 shift, it hits like 4500 rpm's and it feels like it skips and hits the rev limiter. Did yalls do that as well. I just got it out of the tranny shop December of 01. I think it is actually my 4th time in there..
Are there any GOOD parts that i need to ask for if its the 2-3 clutch?
thanks
-Mike
Old May 8, 2003 | 08:18 AM
Smoke T/A's Avatar
Hey man if you don't want ot get that one rebuilt i have a tranny from a 95 TA with less than 32k on it. Shifts perfectly. LMK if you are interested. I'm located in texas too.
Joe
Old May 8, 2003 | 08:26 AM
ONELOUDKAR's Avatar
Thanks SMOKE, but i already have it in the shop. Thanks for the offer though.
Old May 8, 2003 | 02:36 PM
ONELOUDKAR's Avatar
OK, tranny shop guy said no codes were thrown with the tranny, what could possible be wrong with my tranny?
please helpp
mike
Old May 9, 2003 | 04:31 AM
Pro Built Automatics's Avatar
If it is shifting ok at less than WOT, then it is a oil volume problem. This could be due to cross leaks, in the accumulation side of the 2nd gear servo, wear in the front pump (decreasing oil volume), increasing 3-4 clutch clearance due to normal wear & tear, etc. One of the problems is from the factory that the 3rd gear feed hole is on the small side. One common simple fix is to install the Corvette servo, if you do not already have one, another is install the larger boost valve from Trans-Go. There is no guarantee that this will fix it , and this assumes that the 3-4 clutches are still in good shape.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
