So I'm removing the opti and....
Old May 6, 2003 | 11:07 PM
quicksilver97ta's Avatar
I pull the opti and the cam dowl is at a "1" on the back of the opti (opposite to a "6"). Looking at the front of the block this is the 9 o'clock position. Then when I get to the timing gears they are both at the 12 o'clock position. I dont beleive this is at #1 TDC on the compression stroke. I'll put it back together the orientation I found it but tell me that "1" on the back of the opti doesn't mean its firing on #1. Please.
Old May 6, 2003 | 11:14 PM
Re: So I'm removing the opti and....
It does mean #1 TDC and everything you said makes it exactly right. You have no problem.
Old May 6, 2003 | 11:38 PM
Really? Thanks for the reply Shoebox. I have seen too many pics of the timing gears being installed at 6 o'clock and 12 o'clock top/bottom respectively. Is that just to make it easier to line up the dots but @ exhaust stroke TDC?
Old May 7, 2003 | 08:36 AM
So Cam gear @ 12 o'clock
Crank gear @ 12 o'clock = TDC (compresion stroke) for SBC.
I guess my Pontiac V8 is the other way around, I'll have to pull my old Chiltons.
Iamherefornow
Jan 26, 2015 04:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
diazda
Sep 11, 2001 02:42 PM
