G2 sway bars...Worth it?
Old May 7, 2003 | 12:01 PM
RedBeast93Z's Avatar
Question G2 sway bars...Worth it?
Some is gonna sell me his G2 front and back sway bars with the energy suspen bushings for $150 used. Is that a good deal? Does anyone have these bars and how well do they work???
Thanks a lot,
-Ryan
Old May 7, 2003 | 12:16 PM
Carlos01SS's Avatar
Hey Ryan, fellow 93'er!
Aftermarket sways are used to increase handling while cornering, it stiffens the cars side to sloshing about, so it reduces the effects of body lean.
Are you into handling in your car? If yes, then $150 is a real good buy. Brand new from LGMotorsports they run for $329.00...
If you REALLY want to improve your handling, you might want to consider subframe connectors, probably the double diamond type from Kenny Brown, they are weld ons, do not buy the bolt ons. I would heartily recommend them...
Old May 7, 2003 | 12:19 PM
Thanks Carlos,
Ya, I know they make it stiffer and so it should handle better, but I just wanted to know if it really makes a big difference in feel. Like will I handle much better than stock?
Thanks a lot,
-Ryan
Old May 7, 2003 | 12:20 PM
teke184's Avatar
jump on them for $150!!
they are basically the same as the BMR 32/21mm solid bars i installed on my Z...which made a dramatic improvement on handeling and body roll.
well worth it!
Old May 7, 2003 | 12:23 PM
Great!!!
Thanks a lot guys!!!!
Big help!
Old May 8, 2003 | 04:51 AM
Fastbird93's Avatar
For you 93 guys, check this place out -- very knowledgable people and fun to talk to!
Speed Density LT1 Tech Forum
Fastbird93's Avatar
96SilverRam
Nov 20, 2016 11:19 AM
RUENUF
Mar 13, 2016 03:37 PM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
