iron heads
Old May 5, 2003 | 08:23 PM
Got-LT1's Avatar
iron heads
I am able to get my hands on a great set of iron LT1 heads of an impy from a friend for only $40. The question is will the iron heads flow more air than the stock heads (I will port the iron heads, not sure how much porting) and will the airflow be enough to offset the extra weight? Thanks for the help guys.
Old May 5, 2003 | 10:00 PM
Josh-'04 GTO's Avatar
In stock form the iron versions actually outflow the aluminum versions. But if you're comparing ported to ported, there is no reason to believe that the iron heads would come out on top. Since you have to port anyway, I would do the aluminum. Keep the 50 pounds off the front end. Plus, aluminum heads allow higher static compression due to the increased amount of heat pulled from the combustion chamber.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
