What Engine Mods Next?
Old May 5, 2003 | 01:12 PM
Ernster500's Avatar
Question What Engine Mods Next?
Hey Guys,
I'm conteplating doing more engine mods. I'm thinking of doing a cam, RRs, and heads next.
These are the bolt-ons I have so far.
  • Hooker Shorty Headers
  • Hooker Catback
  • LT4 Knock Module
  • ASP Pulley
  • SLP CAI
  • TB Bypass
  • 8mm Taylor Wires
  • HyperTech Programing
  • 160 deg Thermostat
At what point do I need to start looking at fuel injectors, TB and ignition. Should I upgrade those before the cam, RRs and Heads? Or just wait until later?
Thanks in advance!
Ernie
Old May 5, 2003 | 01:25 PM
landon2342's Avatar
Hey man Im in the same boat as you are. ANyone out there with suggestions. Was your knock module worth the money?
Old May 5, 2003 | 01:47 PM
kmook's Avatar
Advanced Tech Moderator
Hey Ernie,
If your just doing a cam and valvetrain i wouldnt worry about injectors for a while. If your doing something radical or head work then i would get larger ones. TBs are contriversal and usually something you buy more towards the end when you are just upgrading ever last little bit.
Old May 5, 2003 | 03:29 PM
Ernster500's Avatar
Well, I bought it for like $25 a while back. I'm sure it doesn't do a whole lot, as far as performance. But I hear it's something you need when going to roller rockers, which I will, hopefully, be doing soon.
Originally posted by kmook
Hey Ernie,
If your just doing a cam and valvetrain i wouldnt worry about injectors for a while...
Hey Ken,
Thanks for the information! Sounds like I can put that money towards the cam and RRs then!
E
Old May 5, 2003 | 03:50 PM
LT1derful's Avatar
Yea...I'd hold off on the TB and injectors. Vavle Train upgrade would be nice. I'd just do springs and rockers and see what you can get out of the car before you leave the bolt-on world. But, what can I say...I've got a cam sittin' in the garage. I just keep telling myself, there's a few tenths left in her, keep pushing it.
Some gears would be nice too.
And, as for the question of the LT4 KM...if you get one cheap, cool. But, get yourself a stock knock SENSOR, wrap it up in foam, cotton, anything thick and zip tie it up by the Kmember, and ground it. Then, unplug your knock sensor from the block (DO NOT REMOVE IT) and plug into the new sensor. Nothing like full timing! And it's cheap and easy too!
cheapchevy
Apr 8, 2015 08:48 PM
alex5366
Mar 8, 2015 11:32 AM
k1996z28
Jan 21, 2015 07:22 AM
johnsocal
Jun 22, 2002 12:18 PM
