Mysterious oil leaking problem
On my 1994 Z28 I have an oil leak and its not coming from the Intake Manifold at all, it clean and dry.
But the bottom part of my opti has oil on it and the oil goes completely down the front of the engine. Possibly opti seal not put on right?
Anybody have any ideas where else this oil leak could be coming from?
All help is needed.
All help is needed.
I would think the opti seal more than likely. Also just a thought but my timing cover was leaking and when I did the cam swap I found out that the bolts on the bottom half of the timing cover were so loose I probably could have taken them off by hand.
Aaron
Aaron
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
