Carbon build-up in TB
Old May 6, 2003 | 03:27 PM
93zder's Avatar
I took off the intake elbow the other day and noticed the TB was kinda dirty with this black stuff that i think is carbon. So i got some TB cleaner and cleaned it (did the running engine thing too). Is this normal? I've got about 90K, but i did this about 50K ago.
Old May 6, 2003 | 03:29 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
its fine
Old May 6, 2003 | 07:19 PM
BigRich's Avatar
yeah, do it every year. carbon might be from EGR.
Old May 7, 2003 | 07:50 AM
93zder's Avatar
I've heard using that TB cleaner can harm the spark plugs - any truth to this?
Old May 7, 2003 | 08:31 AM
GetaZforgetGT's Avatar
I clean my TB about twice a year.
I have never had a problem with fouling spark plugs.
I guess it could happen but I've never heard of anyone having that problem.
Old May 7, 2003 | 08:34 AM
93zder's Avatar
How are you guys doing it - just like the can says? Are you using the whole can each time?
Old May 7, 2003 | 08:50 AM
95TA8280's Avatar
I don't know how much build up you had, but I cam nowhere NEAR using the whole can.....all I needed was like 5-6 sprays and I was good. When you do it put a rag underneath the TB to catch any of the stuff that falls out, and also have someone hit the gas pedal and clean in there too.
Old May 7, 2003 | 10:01 AM
93zder's Avatar
I didn't use a whole can either, but i did use probably 1/2 a can because i wanted to make sure i cleaned the intake inside as well and do a good job. I throttled it myself from the linkage and sprayed at the same time.
Old May 7, 2003 | 10:07 AM
Sometimes the carbon builup is from oil pulled out of the passenger side valve cover, into the line that goes to the side of the throttle body. The passage inside the TB runs under the top cover plate, to a port in front of the blades. You might want to take the top cover plate off and see if there is any oil builup in the top of the TB. Some buildup seems to be "normal".
If you have a lot of oil there, clean it out, then check the PCV valve - drivers side of the intake manifold/center - and make sure it isn't plugged.
Old May 7, 2003 | 10:17 AM
SloMofo's Avatar
I just used the seafoam deep creep. Sprayed it into my TB. Used about 3/4 can.
Old May 7, 2003 | 10:46 AM
93zder's Avatar
i just changed out my PCV valve, i will check the under the TB plate too.
thanks.
Old May 7, 2003 | 11:06 AM
97Z-M6's Avatar
that sig is funny.....man
i read all the other post in the for sale section.
carguy0119
Apr 11, 2016 11:11 PM
CARiD
Sep 30, 2015 05:44 AM
karpetcm
Aug 14, 2015 03:02 PM
Aug 5, 2015 08:35 AM
RX Speed Works
Jul 24, 2015 02:25 PM
