Help w/ Removing PS Pump
Old May 7, 2003 | 08:01 PM
25th-transam's Avatar
Well i took off the alt. and removed the bolts holding the power steering pump to its bracket the only thing left are the lines, the bottom one (metal one) seems to be impossible to get any wrenches on. does anyone have any tips for getting around in there or removing anything for better access.
Thanks,
Kurt
Old Jun 19, 2005 | 06:37 AM
jon36's Avatar
Re: Help w/ Removing PS Pump
im having the same problem as u. Not sure which wrench to use on the bolt that is connected to the metal line.
Old Jun 19, 2005 | 09:30 AM
Ricardo's Avatar
I used a flare nut wrench to loosen the tube nut. It is a tight fit but you can get it in there after removing the pump mounting bolts.
Old Jun 19, 2005 | 01:53 PM
OBE1 95Z28's Avatar
I have a set of open end wrenches where the the open end is 90 degrees from the normal position. Works great for that metal line.
Old Jun 19, 2005 | 03:57 PM
jon36's Avatar
im about to pick up some open end wrenches up from sears then. thanks for the info
Old Jun 19, 2005 | 04:12 PM
OBE1 95Z28's Avatar
I've never seen the 90 degree offset wrenches at Sears. I got this set at Harbor Freight. I'd like a better quality set but I haven't found one yet.
Old Jun 19, 2005 | 04:43 PM
jon36's Avatar
do u know the size of the line wrench dont really want to by the whole set if they sell them indavidually
REDNECKISBOSS
Mar 22, 2015 08:31 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
