Scanmaster Code
Scanmaster Code
Just got a reading of code 48 which is the MAF sensor circuit, I checked to make sure the sensor was plugged in properly, it seemed ok, any other idea's?
car does start up and idles well.
thanks
thanks
I've seen a lot of cases where the +12V power supply (pink wire on the harness connector) will break and you lose power to the MAF. With the ignition on, check the pink wire for +12V at the MAF.
