SES light on. Code 32- EGR recirculation?
Old May 7, 2003 | 09:59 AM
95_RipperZ's Avatar
Just driving around today the light came on so I checked the scanmaster and found code 32. Then turned the car off and back on and the light went away. What does this mean? Time to delete the EGR?
Old May 7, 2003 | 11:53 AM
fbird95's Avatar
Sounds like the ERG is not operating properly or is stuck, but i'm not the expert on code readings. You could delete, i would just replace it myslef.
Old May 7, 2003 | 12:25 PM
95_RipperZ's Avatar
Would keeping it help anything? I mean my car is already passed emissions for the next 2 years.
Could this also be the cause of a slight stumble at idle?
Old May 7, 2003 | 12:38 PM
EviLBoX's Avatar
If your EGR is stuck open it could cause a rough idle. If you really wanted to keep your EGR, you could pull the EGR valve and clean it with some carb cleaner, that may do the trick. Otherwise the EGR really isn't necessary other than for emissions.
Old May 7, 2003 | 01:42 PM
BlkDth's Avatar
What do you need to do to delete the EGR? Do you have to reprogam the computer?
Old May 7, 2003 | 07:37 PM
EviLBoX's Avatar
No matter what year car you have, you'll need 3 block off plates, 2 for the intake manifold and 1 for the header/manifold. If your car is OBDII, you will have to have it programmed out.
Old May 7, 2003 | 08:02 PM
95_RipperZ's Avatar
Consider it gone. Anyone got a link to where I can get the blockoff plates? I have seen them before.
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
