Oil Pump
Old Jun 27, 2005 | 10:10 AM
JDW18's Avatar
Oil Pump
what all needs to be done to put in a High Volume pump? is it difficult with i need to pull the motor or can i do it under the car just by pulling the oil pan? i know i need the pump and new pump shaft with the steel guide but will i need a pickup or can i used the one from the old pump and what about the oil pan? does it have to be deeper? and will i see much of a change in oil pressure with a HV pump?
Old Jun 27, 2005 | 10:40 AM
Re: Oil Pump
A logical question would be why do you feel you need a high volume oil pump? There are some huge HP strokers and stock displacement engines, running the stock pump with no more than a blueprint on the pump, "white" high pressure spring and a tack-welded pickup. In fact some people with stock pans have cited pump starvation problems with the HV pumps.
Old Jun 27, 2005 | 10:44 AM
JDW18's Avatar
Re: Oil Pump
im just having pressure problems and have been putting 10w 40 synthetic in the car and i think the pump is getting worn out its got 86k on it should i just get a melling standard volume pump as use the white spring which is 40-65 psi i think? Anyone know where i can get the spring?
Old Jun 27, 2005 | 09:59 PM
Re: Oil Pump
The white spring is a GM part. P/n can be found on the part numbers page in my sig. Install a new pickup, too. That should be automatic, IMO.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
