mac headers on my 1 inch lowered z28.
Old Jun 25, 2005 | 11:10 AM
80TA's Avatar
I want to buy some macs soon. My car is dropped with 1 inch hotchkis springs. Will I have problems hitting the macs in normal driving? Is ground clearance much less with them. I do have kyb agx shocks so can dial the shocks up a bit if need be to help out if headers bottom.
Old Jun 25, 2005 | 01:07 PM
1995greenTA's Avatar
Re: mac headers on my 1 inch lowered z28.
Im assuming your talkin about mac mids, which I wouldnt think you would have any problems with them and a one inch lowering kit. mine werent much lower, if any than stock
Old Jun 25, 2005 | 01:22 PM
80TA's Avatar
Yep mac mids.
Old Jun 25, 2005 | 02:20 PM
Shouldnt have any problems, maybe some one else will chime in and back me up?
Old Jun 25, 2005 | 03:22 PM
blaze309's Avatar
My car isn't lowered at all and I have mac mids and I scraped my cat once on a speed bump but I think it's only because I had two other people in my car so it was sitting a little lower. Just go over them slow and you'll be just fine.
Old Jun 25, 2005 | 03:39 PM
Steve0's Avatar
I have them and I dunno if you'll be OK with a lowered car or not. I have half a soda can's worth of ground clearance and I'm on stock springs. Other people report the same thing, others have their y pipes tuck up higher.
http://web.camaross.com/forums/showt...ound+clearance
I tried adjusting mine only to get leaks. Today it still sits as pictured.
Old Jun 25, 2005 | 04:53 PM
The lowest part of my exhaust when I had macs, was my cat, which was still in the stock location. so If you have macs, and a cat back, with a cat or ORP, i wouldnt think they would hang any lower. I couldnt slide my shoe under my cat sideways with stock springs.
Old Jun 25, 2005 | 05:10 PM
stereomandan's Avatar
As others have said, it's the cat and the flanges on the cat that sit the lowest. Even with a straight pipe in place of the cat, the ball/flare flange will sit the lowest.
My MAC mids with stock springs (which may have sagged 1/2" over the last 8 years) has 3 1/2" of clearance at the lowest point.
Dan
Old Jun 25, 2005 | 05:14 PM
Z28Nut's Avatar
I have Mac Mids on a non-lowered Z, but I ditched the cat for an ORP w/3" manual cut-out. With stock manifolds/cat, I scraped the cat on the end of my drive every time someone else was in the car and sometimes when alone. After Macs and ORP/cut-out I scrape very rarely with 1 person in car with me. The Mac Mids give a very close to stock clearance on the exhaust. I need to rent a concrete grinder so I can put on some Hotchkis springs.
Old Jun 25, 2005 | 09:44 PM
CatsTasteGood's Avatar
I have hooker lt's, which hang lower than the macs my hookers replaced and I dropped my car 2 inches. 10 out of 10 roads in my area are as smooth as my little sisters shifting and the only thing I ever hit is the flange on the headers, and thats rare.
Old Jun 26, 2005 | 02:13 PM
BeaversTA's Avatar
I'm running mac's with a LS1 pro kit and they never hit the ground. But the lowest point on my car are the sub fram cont. They work great for pushing my car over speed bumps.
Rich_z28
Aug 29, 2002 10:44 PM
phantasm99
Aug 28, 2002 11:01 PM
Burn_Out
Aug 18, 2002 08:49 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
