OBDI to OBDII
Old Jun 23, 2005 | 01:09 PM
Dtimekw's Avatar
OBDI to OBDII
Is there a way to convert my 95 Z28 to OBDII? I have the 16 pin connector. The label under the hood says OBDI compliant. I bought a laptop dyno to check codes and then found out that it is OBDI. The 16 pin thru me off. If there isn't, is there a way to plug a laptop into OBDI? Thanks
Old Jun 23, 2005 | 01:25 PM
jchevy's Avatar
Re: OBDI to OBDII
Im sure there is a way to convert, but it wont be easy. The OBD2 has some extra sensors so you would need to add those to your car. Will be much easier and probably cheaper to buy the correct software.
Old Jun 23, 2005 | 01:30 PM
madwolf's Avatar
Re: OBDI to OBDII
Easier to buy a cable for your OBD1.
www.akmcables.com
Get the "crimp" style cable. I think it's like $65.
Old Jun 23, 2005 | 02:47 PM
brians96Z's Avatar
Re: OBDI to OBDII
I would keep OBD1 if I had the chance man......
Old Jun 23, 2005 | 05:29 PM
Re: OBDI to OBDII
OBD-I software is much cheaper. I sure wouldn't convert to OBD-II just for diagnostic reasons.
Old Jun 23, 2005 | 05:36 PM
SS MPSTR's Avatar
Re: OBDI to OBDII
there is certainly no performance benefit.
Old Jun 23, 2005 | 10:13 PM
atljar's Avatar
Re: OBDI to OBDII
They rev higher, also no high stall issues. But for diagnostics, blah.
Old Jun 23, 2005 | 11:38 PM
Jameslt1TA's Avatar
Re: OBDI to OBDII
obd1 to obd2...lol. I think that obd1 makes more power and is easier to tune than obd2. I see lots of people converting to obd1 from 2. As for the high stall issue, isnt there a fix for that.
Old Jun 23, 2005 | 11:43 PM
jchevy's Avatar
Re: OBDI to OBDII
As far as i know there is no power difference. Actually if anything i would think OBDII would make more power becase there are more sensors and the engine is better managed.
I converted to OBD1 b/c I had LT1 edit for OBD1 and also Datamaster.
Old Jun 23, 2005 | 11:50 PM
Jameslt1TA's Avatar
Re: OBDI to OBDII
It says on Ion's(madz28) website that obd1 makes like 10hp more or something.
Old Jun 23, 2005 | 11:56 PM
jchevy's Avatar
Re: OBDI to OBDII
Well he would know better than i would.
I thought that was going from a stock tune to his tune with lower fan temps, premium fuel, etc.
Maybe he can chime in and let us know.
Old Jun 24, 2005 | 05:53 PM
arnie's Avatar
Re: OBDI to OBDII
Also, how 'bout the use/response of the VE tables?
aj2494
Mar 12, 2015 10:17 PM
ollie-99
Feb 10, 2003 12:48 PM
SnkEatr
Feb 9, 2003 09:56 PM
96z
Feb 6, 2003 03:23 PM
blackhawk96
V6 Tech
Aug 27, 2002 07:17 AM
