2otl installed
Old Jun 27, 2005 | 07:08 PM
961le's Avatar
Thumbs up 2otl installed
fit was excellent,hardest part was removing original exhaust. the sound was melodious not as quiet as i had hoped but the tone makes up for the volume only problem is an exhaust leak in the slip fit at the cat. it had obviously leaked on the old system too because of the soot all under the car. can i just remove that joint and smear some rtv around it ? or is there a better way to get rid of this leak?
Old Jun 27, 2005 | 07:28 PM
turbo_Z's Avatar
Re: 2otl installed
You could always weld it all shut.. thats the only way I could seal mine entirely. The 2OTL is a great catback.
Old Jun 27, 2005 | 07:33 PM
961le's Avatar
Re: 2otl installed
i was thinking maybe i put the clamp on the wrong place. should i have put it over the split in the pipe that goes over the cat . i put it behind that split towards the cat more? i really dont want to weld it if i can help it.
Old Jun 28, 2005 | 07:08 PM
Derrick Redd's Avatar
Re: 2otl installed
I have 1 3/4" SLP headers & Y pipe with SLP 2OTL rear section. I really like the way it sounded. I had to replace the SLP muffler because it had internal issues. I put a Dynomax Ultraflow 2OTL muffler in it's place. Still sounds great.
Old Jun 28, 2005 | 07:25 PM
1racerdude's Avatar
Re: 2otl installed
Go to a 18 wheeler parts house or maybe NAPA and get a stainless 3" or 4"wide band clamp,remove your "c" type clamp and install the center of the band clamp at the joint and tighten 2 cap screw's.That will seal it as it pulls down to each pipe like a skin. Then when ya are ready to remove it ya can.
Old Jun 28, 2005 | 09:03 PM
961le's Avatar
Re: 2otl installed
it is fixed. permanantly it seems. the ubolt clamps put a nice dimpled effect on my pipes so i could not take it apart to fix the leak. so i reused my original c clamp type with the ubolt and cinched her down until the leak went away. when i have to remove the exhaust though im in a fix for sure. so now i have two clamps on the slip joint at the cat
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
grendal
Apr 15, 2010 05:20 PM
