pushrod length
Old Jun 23, 2005 | 12:31 AM
94z28blue's Avatar
pushrod length
Ok so my heads recommend a comp 7949-16 (.100-inch longer than than stock) in the instructions but when they installed them they used 7940-16 (stock length) Could this be causing it not to put out the power that it should?
Old Jun 23, 2005 | 12:41 AM
1racerdude's Avatar
Re: pushrod length
It might.
It will cause early guide wear,depending how far they are off.
Recommended length is not always correct.The length should be checked with an adjustable pushrod and a solid lifter to get the pattern on the stem right,then measured and that's the ordering length.
Old Jun 23, 2005 | 03:33 PM
94z28blue's Avatar
Re: pushrod length
so you think i should just get new ones that are measured then? would it be hard to do?
Old Jun 23, 2005 | 03:40 PM
1racerdude's Avatar
Re: pushrod length
YOU need to measure YOUR engine and get the right length.
The one's ya have might be right,who knows until ya measure.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
