Which bolts for accesory bracket??
Old Jun 23, 2005 | 11:25 PM
Silvershark's Avatar
Are the bolts that attach the accessory bracket to the heads the same size? I was able to get the one in, upper right hand corner. However the other bolt seems too long.
If someone could give me a rundown of what bolts go where in this picture I would appreciate it!
IE: size and location
http://shbox.com/1/accy_brkt.jpg
I measured the bolt sizes that I am using with my tape and they are as follows.
1. 3 bolts at 1 3/8" thread length total bolt size = 1 5/8"
2. 1 bolt at 2 1/2" thread length, total bolt size = 2 3/4"
3. 1 bolt at 1" thread length, total bolt size = 3 1/4"
4. 2 bolts at 1" thread length, total bolt size = 1 1/4" I believe these are the Power steering bolts.
5. 1 bolt at 1 1/8" thread length, total bolt size = 2 1/8"
Old Jun 24, 2005 | 12:04 AM
sssalah's Avatar
Re: Which bolts for accesory bracket??
The bracket is held by a total of 4 bolts all of them are 3/8-16 thread and are black. The top ones on the passenger side head are about 1" with full thread. The other 2 that attach the bracket to the block, the longer one holds the wires bracket and the shorter one goes behind the tesioner. Power steering bolts have a 10 mm hex head with M8 thread.
The other bolts are for the alternator, the shorter ones maybe the same length as the bracket bolts to the head but they are white (galvanized).
Old Jun 24, 2005 | 12:11 AM
Ok, I found the power steering pump bolts, and the accesory mounting bolts to head. I think I found the 3 to the A/C compressor, if they are roughly 1 3/4" bolts. So I just need the two to the block. I am guessing they are longer than 2" because I measured the accesory bracket where they go in and its roughly 2 inches.
I also have the alternator bolts.
Old Jun 24, 2005 | 12:07 PM
If anyone can give me an update on the two bolts that bolt into the block I would appreciate it.
Old Jun 25, 2005 | 04:47 AM
sssalah's Avatar
From your list, #2 which is 2.5" is the one that goes behind the alternator ( to the lowest point) and the longer one which is 3.25" holds the middle of the accessory bracket and holds the small plug wires bracket.
Old Jun 25, 2005 | 04:26 PM
Thanks, I got them all figured out except the AC Compressor/Condensor pulley bolts.
Old Jul 21, 2005 | 07:48 PM
groundpoundinlt's Avatar
i have a similar problem...i have the two bolts that bolt to the head but have lost the two that bolt to the block...i need to know what size and how long by saturday...any help would be much appreciated
thanks
bubba
Old Jan 21, 2007 | 08:14 PM
seawolf06's Avatar
Anyone figure out the size for the power steering pump bolts?
NVM, M8 x 1.25"
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
96SilverRam
May 5, 2015 09:56 PM
maybe2fast
Mar 16, 2015 09:45 AM
Jlo
Feb 3, 2015 09:41 PM
