my car wont go to closed loop
Old Jun 23, 2005 | 02:04 PM
SUTTERERMAN85's Avatar
i am getting black smoke out the back and no codes with datamaster, and i cant give the car any gas or it will die. i have to hold the pedal down to get it to start also. O2 MV are 900 and change, INJ DC is 3.0 at idle, BPW MS is 4.78 at idle. i dont know what is going on. if someone would take a look at my log i would really appericate it. thanks
nick
Old Jun 23, 2005 | 02:43 PM
MEAN LT1's Avatar
Re: my car wont go to closed loop
Couple different reasons why the computer wont go into closed loop. One of which is that one of your o2's are bad. Check tp make sure there bothing moving. they should not be staying at one place. If so then there is your problem.
Old Jun 23, 2005 | 02:46 PM
TUNDRKYS's Avatar
another thing to check is the temp on the sensor in the water pump. If it's too low, you won't go into closed loop either. I think it needs to see 180*, but I'm not too sure on that number.
Old Jun 23, 2005 | 03:26 PM
Unhappy Re: my car wont go to closed loop
my o2 are in the 950's and 940's they are moving around back and fourth. how do i check the coolant temp sensor? how could that make me run so rich? i have to hold the pedal down to start it and then if i give it any gas it will die. i can email you the datamaster file if you want to look at it. PLEASE.
Old Jun 23, 2005 | 04:05 PM
Gripenfelter's Avatar
Make sure there are no bent pins on the MAF connector. Make sure the MAF is fine...swap in a different one to test.
Old Jun 23, 2005 | 04:24 PM
already did off of my burb. same prob. could my PCM be bad?
Old Jun 23, 2005 | 05:29 PM
i think i fixed it. i swaped the coolant temp sensor with an old one off my truck that was good still and i logged it and she went into closed loop. seems to be running right now. thanks a million. i owe you one. by the way i cant believe that it does so much to the car!!
nick
Old Jun 23, 2005 | 07:26 PM
TUNDRKYS's Avatar
Well when it happened to me, I burned my clutch up trying to keep it moving. Now I keep an extra sensor in my glove box.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
