where to wire fans to???
Old Jun 23, 2005 | 11:27 AM
hot95camZ28's Avatar
before i blew a head gasket my fans quit working. Instead of fixing the problem the right way i cut up the factory wiring and wired them to the battery with a switch in the car and a in line fuse. i was wondering what i can wire them to under the hood so at least one will come on when the key is on, and (if is okay to do this??) wire the other one to a swith like how i had them before!
any feeback will be appreciated since i dont want to blow any more head gaskets!
Old Jun 23, 2005 | 01:01 PM
Re: where to wire fans to???
ttt
Old Jun 23, 2005 | 02:25 PM
Compstall's Avatar
Why don't you try putting the wiring back to stock and changing out the fan relay?
Old Jun 24, 2005 | 03:24 PM
All The Relays Were Good. Does That Mean It Was The Temp Sensor Or Could It Be More Complecated?
Old Jun 24, 2005 | 11:28 PM
RansZ28's Avatar
There is a solid blue and solid green wire in the connector near the pcm. I beleive the green is the low and the blue is the high speeds. I tapped into them and have a switch w/leds in the dash. Works great!
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
