Will This Work??(Battery Relocating Wiring)
Old Jun 21, 2005 | 12:57 PM
Camaro4LifeSS's Avatar
I relocated the battery to the trunk and I wanted to make sure the wiring I did will be fine.Reason i'm asking is because I won't be able to start it for a while because of other mods.I ran the positive up to the starter,then I ran a wire from the starter to the alternator,and then another wire from the starter to the junction box.I was also wondering where everybody ran their ground to in the trunk.I've heard most peoples problems have been from a poor ground so I want to be sure I ground it in a good spot.My ground wire up front is off the motor mount bolt and to the frame near the front sway bar mounts.Think that will be a good ground for up front?
Thanks in advance,
JE
Old Jun 21, 2005 | 01:54 PM
JohnD's Avatar
Re: Will This Work??(Battery Relocating Wiring)
I've heard about installs where the ground was solidly bolted to the body pan at the rear and it worked ok but if I was doing it, I would run two wires from the battery and put the positive one on the post where the battery connected before and the ground on the same post as before. I've just seen too much weirdness in cars when grounds get moved around.
liamcg97
Nov 25, 2019 05:55 PM
97z28k&N
Jan 9, 2015 04:58 AM
Jazsun
Dec 29, 2014 12:14 PM
RedLineRev
Jan 23, 2003 03:51 PM
