Oil pressure sensor , How to change it
Old Jun 27, 2005 | 08:07 PM
jsz28's Avatar
Well i need to put a new one on and i cant get the old one off. Is there a special tool to pulling these off. Just need some help.
Old Jun 27, 2005 | 09:47 PM
Re: Oil pressure sensor , How to change it
Yes, there is a special socket available at most auto parts stores. Using one with an extension and pointing along a line from the brake booster toward the sensor, along the firewall, should enable you to reach it.
Old Jun 27, 2005 | 10:04 PM
OBE1 95Z28's Avatar
As Shoebox stated, it's a special socket. It's a 1 1/16" socket that extra deep (deeper than a standard deep socket). Once you remove it don't start the engine until it's replaced as you'll have a massive oil leak (pressure side of the oil pump).
Old Jun 27, 2005 | 10:23 PM
pearlpurple's Avatar
if it is the same size as my 93 then you can use an oxygen sensor socket,, that is what I used. On my 93 it is located right next to the oil filter
Old Jun 27, 2005 | 10:24 PM
That's not where it is on a 1995 and the sensor is different.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
