hard start up, won't start
Old Jun 22, 2005 | 01:52 PM
romoranger's Avatar
lately i have been having hard start up problems. sometimes it will turn over, somtimes it will not turn over at all.when it does turn over it will turn a couple times, then die. then my battery voltage is low. when i can get the car to start i have to give it a lot of gas to get it to fire.
any one have an idea?
Old Jun 22, 2005 | 02:03 PM
flusz28's Avatar
Re: hard start up, won't start
battery-starter-wires might be dirty from this items. spark plugs might need changed. my everyday car i bought used-95 grandam. one day it started acting like a battery so i had money to burn so i replaced the battery and starter since i had no clue how old the battery was and the starter was stock. then one morning i come out to start the car and it wouldn't turn over. but yet acouple hrs before that it was fine. pulled the plugs and they had nothing left for a spark.
Old Jun 22, 2005 | 02:09 PM
romoranger's Avatar
new plugs 500 miles ago, new wires 500 miles ago, new opti 550 miles ago, all batter cables read correct volatage when they are hooked up to an voltmeter, new alternator 50 miles ago
things that are old and still left, starter, fuel pump, injectors
Old Jun 22, 2005 | 02:26 PM
flusz28's Avatar
pull the starter and get it checked- test fuel pressure on the shrader valve. should be 38-40 range with the key in the run position and with all the fuel vacumm lines hooked up. check the volts going to and from the injectors and try it while the car is being cranked over. could be fuel pump never now. are you getting good spark from the coil, is the ICM giving of enough volts? it might be going bad or the coil. its hard to tell cars are a pain in the a$$ they don't always act the same if something is wrong.
Old Jun 22, 2005 | 02:29 PM
romoranger's Avatar
i know injectors are good, i know volatages too all of them are correct, i cm is giving enough volts. right now i am looking at either starter, fuel pump, or battery. given these three and my symptoms, which would you think?
Old Jun 22, 2005 | 02:31 PM
romoranger's Avatar
oh yeah, and when i brought my battery to checker, they said its charge was full, we tricklend chraged it for 30 minutes just to make sure but it was full after the 30 minutes
it is a dry cell battery
eazyZ
Mar 1, 2015 07:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
teedoff59
Aug 8, 2002 01:36 AM
