Thermostat.
Thermostat.
At my first and only attempt to change my thermostat. I ran into a problem. I Pulled the plug at the bottom of the radiator and nothing came out. A few drops of crud, that was about it. Any other way to drain the coolant? I don't wanna just take off the thermostat housing and soak my opti. Any suggestions?
Re: Thermostat.
Originally Posted by TruDualed95Z
I didnt drain the coolant to replace the t-stat and I've had no problems.
Re: Thermostat.
Originally Posted by 1FstFormulaV8
It was coming out of the t-stat housing as soon as I started loosening the bolts.
If not... umm yeah do that... the coolent system becomes pressureised when it heats up.
FastZinTennessee
Oct 24, 2003 08:01 PM
