coolant bleeder pipe
Old Jun 22, 2005 | 10:11 PM
tintagel13's Avatar
have a 94 z28 and i have sprung a leak on the rubber elbow that is attached with the big metal clamp to the metal bleeder pipe...anyone know what to ask for at the parts house or is this a dealer item...any help would be greatly appreciated...
Old Jun 23, 2005 | 10:30 PM
red1994z28's Avatar
Re: coolant bleeder pipe
May want to give a better description because I can't figure out what you're talking about...
Old Jun 23, 2005 | 11:17 PM
luckyou03's Avatar
thats a major hose to replace. I recommend getting the Goodyear Hi-Miler blue hose kit from summit. I think the part number is: GTR-5006
That one hose from the dealer is like $170, so I'd be cheaper to just buy all of the hoses. It sucks but the goodyear are suppose to be "10 times stronger than the stock hoses" and "lasts 5 to 10 times longer than regular hoses."
Old Jun 24, 2005 | 12:02 AM
blwnlt4's Avatar
The hoses are dealer only, when mine sprung a leak right near the bleeder i used a saw blade and cut the press fitting off and used a regular hose clamp, works fine.
Old Jun 25, 2005 | 02:06 PM
luckyou03's Avatar
It's dealer only for the pre pressed fitting pipe, but you can get all of the rubber hoses in the hi-miler kit and use hose clamps. I think it would be a bad idea to install just one replacement hose.
Old Jun 25, 2005 | 05:53 PM
chuckd4more's Avatar
I have the goodyear blue but not installed yet. Will do when I rebuild. I do have to say that my 95 with 160k+ has yet to have a hose leak. Just lucky I guess
Old Jun 25, 2005 | 08:39 PM
ubiquitus's Avatar
when I replaced all of my hoses, I just used regular generic heater hose tubing and cut the ends off the bleeder valve and reused it. cost me nearly nothing and works perfectly.
Old Jun 25, 2005 | 10:26 PM
tintagel13's Avatar
thanks for all the replies...that's what i did...used a dremel tool on the pressure clamp then got the elbow piece at the chevy place...had replaced all the hoses but that one...
blac94Z
Feb 15, 2021 09:43 PM
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
Latronaxe
Jun 10, 2015 02:08 PM
Queens94z28
Mar 23, 2015 08:06 AM
