Oil in my tail pipes
Old Jun 23, 2005 | 11:39 AM
95 firechicken's Avatar
The other day i noticed that there is a few drops of oil comming out my tail pipes any ideas ?
Could my rocker arms be a little to tight ?
Old Jun 23, 2005 | 11:43 AM
jpolz's Avatar
Re: Oil in my tail pipes
You sure it's oil and not just water mixed with some soot from the inside of the exhaust system?
The only way I could see oil comming out the tailpipe is if you had leaking valve stem seals or piston rings AND you had a cylinder that wasn't firing becuase any oil that does get in the cylinder should burn up.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
SergheiS
Apr 26, 2015 08:15 PM
Ringmaster72
Apr 2, 2015 08:32 PM
CaRParts102
Dec 6, 2014 08:45 AM
