Asr 94
Old Jun 25, 2005 | 07:16 PM
Daniel6718's Avatar
Asr 94
i have a 94 camaro z and i had some light burned out in my dash..im fixing them and when i put it all back together turn on the car and the ""asr off"" light is lit up??? my car since its a 94 doesnt even have an option for it does it??? and theres no switch for asr either...and ive looked at the rearend and dont remember seeing anyhting for it...so why is this light lighting up???
thanks
Daniel
Old Jun 26, 2005 | 10:11 AM
slopokrodrigez's Avatar
Re: Asr 94
Most indicator lights in the instrument cluster have power going to them all the time and when lit, the ground is applied. That is, they are switched on and off by applying or removing ground.
In your case, the external line that would have been used had traction control been on your car is probably pinched somewhere and contacting ground. It's a simple fix to remove the wire from the connector that provides the ground to the light. It should be the only purple/white wire going to the instrument cluster.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
dluna333
15
Mar 13, 2015 12:30 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
