opti vent hoses...it hooks into the intake elbow?
Old Jun 24, 2005 | 11:02 AM
blackztpi's Avatar
I'm converting from a non vented to a vented setup. i saw the venting diagram and it shows one of the opti vent hoses going to the intake elbow??is this ligit? if so, how can i make it work on a 94? thanx
Old Jun 24, 2005 | 11:14 AM
slverbullet's Avatar
Re: opti vent hoses...it hooks into the intake elbow?
use a tap to put some threads into your intake elbow. then get a piece to thread into it from lowes that will also allow you to hook a vacuum line onto one side of it. you can find this piece in the plumbing aisle. youll know what i'm talking about when you see it.
or you could always buy the vortech intake elbow for like $80-90 at summit. it comes with the fitting to actually place into the itake elbow housing. it looks a lot nicer but does require you to still tap the hole for the fitting and to use a die to thread the iac.
dont forget, you also have a line going into your intake manifold.
Old Jun 25, 2005 | 12:19 AM
blackztpi's Avatar
got the intake fitting covered.... i'll see what i can find for a 90 degree elbow in the plumbing section. thanx
Old Jun 25, 2005 | 03:24 AM
97WS6SCharged's Avatar
It's alot easier to put a small hole into the coupler that connects the elbow to the MAF.
Old Jun 25, 2005 | 07:00 AM
All you have to do is poke a hole in the intake elbow and install a 90° vacuum fitting into it. Use a dab of RTV if needed.
Old Jun 25, 2005 | 12:12 PM
chuckd4more's Avatar
You don't have to tap the hole, just get a fitting and a rubber grommet that will fit and put a hole in the elbow to recieve the grommet. It's up to you though but that's how my TF elbow came and I just had to drill the hole.
Old Jun 25, 2005 | 12:20 PM
okay, well sorry about the tapping info. i hadnt messed with the plastic elbow that much. i had to switch to the metal one early on due to a crack in the stock piece. good info out there for whatever you need though.
Old Jun 25, 2005 | 06:11 PM
I guess the Vortech has it tapped but my Trick Flow came with the gromet and I just drilled the hole. Sorry about the confusion. If it's stock, like shoebox said, just poke a hole in the elbow.
Old Jun 26, 2005 | 03:23 AM
heliskiier1's Avatar
I just did mine...it's awesome...there's a better alternative to the intake elbow! The EGR vacuum works good if you got the correct one way valve vent line.
Send me a line if you want the instructions. The setup rocks in my 94!
mudkat
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
