LT4 starter install problems...
Old Jun 27, 2005 | 03:27 PM
RacerTim's Avatar
Everything is ready to fire up on the car, but the damn starter just wont line up properly. I have tried up to 5 shims to no avail. Its a 94 with a new motor and M6 FYI. I turn and key and get a click. I can go down there and look, and the gear is still engaged to the flywheel, and stays that way until loosen the starter, at which point it will retract back into the starter housing. So I am sure its not lined up right. I had no problems with the old starter when I took the motor out, so this is completely confusing me. Not to mention, the new motor is in the car and ready to roll and this is the only thing holding me up now. Please help!
Old Jun 27, 2005 | 04:00 PM
GOTPLZ2's Avatar
Re: LT4 starter install problems...
You might want to check the charge on the battery. I had this problem with a motor and I tried shimming it and come to figure out it was the battery not having enough charge and it clicked everytime i tried to turn it over. If you have a lt1 starter and block you shouldn't have to shim it at all.
Old Jun 27, 2005 | 04:46 PM
blunto's Avatar
Check for voltage at the starter while cranking. The pinion can get jammed in the flywheel due to improper/inconsistent voltage. This seems a lot more likely than an LT4 starter not fitting correctly. Good luck!
Old Jun 27, 2005 | 09:51 PM
Got the right flywheel?
Old Jun 27, 2005 | 10:32 PM
BigJustinZ28's Avatar
mine bolted right in ........
Old Jun 27, 2005 | 11:28 PM
RacerTim's Avatar
Factory resurfaced flywheel.
LeftoverChinese
Jan 14, 2024 03:03 PM
Jeff1904
Jan 3, 2015 12:00 AM
GigaMp3z
Feb 20, 2003 02:57 PM
