Overheating Question
Old Jun 21, 2005 | 01:31 PM
joshp007's Avatar
Ok guys I just installed my 355 LT1 in my car. I flushed my radiator, installed all new hoses, new thermostat, bled the air out of the system, and I am running a csr elec. water pump. It gets really hot when it is just sitting at idle but it doesnt get to the red line. As soon as I drive it and get maybe a block down it overheats. Any idea what I can check?
Old Jun 21, 2005 | 01:35 PM
justnrt's Avatar
Re: Overheating Question
try a different stat, and bleeding the system again just incase an air pocket is trapped. also make sure your fans are comming on. since youve rebuilt, is your pcm stock? if so the fans dont come on until a pretty high temp.
Old Jun 21, 2005 | 01:36 PM
justnrt's Avatar
also whats the flow rate of your electric water pump.
Old Jun 21, 2005 | 01:47 PM
joshp007's Avatar
I am unsure of the flowrate. I think it is 37 or 35 gpm. Yeah the pcm is reprogrammed but it was programmed to come on sooner. The fans do kick on though. I guess trying the new stat would be best huh
Old Jun 21, 2005 | 02:02 PM
justnrt's Avatar
yeah, the stat could be stuck causing your problems. this is assumming the pump is working correctly.
Old Jun 21, 2005 | 02:04 PM
joshp007's Avatar
Yeah pump works great so I hope that is it. Sucks cause it is new Haha well I will try that tonight. What is the best way to bleed the air out of the system?
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
