plug wire clearance from header 1/8"
Old Jun 22, 2005 | 06:54 PM
gibbylt1's Avatar
Is this enough space? I have the Taylor 8mm ovc kit from Thudner Racing. It is tied strong and won't move, but it is close to the header. Will this burn?
Old Jun 22, 2005 | 06:55 PM
blind527's Avatar
Re: plug wire clearance from header 1/8"
It's possible...
You should have gotten the elitesparkplugs.com wires that come with 1200 degree heat shields. If you position them right, they shouldn't burn.
Old Jun 22, 2005 | 07:49 PM
salty's Avatar
Or you could get those aftermarket firesleeves. I've heard they work well.
I'm going to use those when I install my headers. I have cheap(but new)wires, so I'd rather use the wires for awhile before scrapping them.
I think these sleeves are a little expensive, though. Maybe someone will chime in and help us both out with a cheaper alternative...
Old Jun 22, 2005 | 08:01 PM
blind527's Avatar
I think those sleeves are about 2-4 dollars per sleeve? If you got only the ones needed where it was too close, it shouldn't be expensive.
Old Jun 22, 2005 | 09:56 PM
salty's Avatar
What brand sleeves are those? Are the ones in the generico import section of advance auto heat resistant enough? I was thinking of the taylor firesleeves...
Here they are at summit...
http://store.summitracing.com/defaul...4845355+400235
Old Jun 23, 2005 | 12:09 AM
Maldo's Avatar
no: those sleeves work ok but they do not give you the protection like our wires. (Those type of sleeve tend to slip around the wire plus they look like: barf: after a few heat cycles.....
Check out what our wire look like compared to the regular heat shield stuff you get from summit.
check out our wires and you can really see the difference and quality
http://www.elitesparkplugs.com/images/IMG_1083.JPG
http://www.elitesparkplugs.com/images/IMG_1071.JPG
http://www.elitesparkplugs.com/images/IMG_1108.JPG
http://www.elitesparkplugs.com/images/IMG_1128.JPG
http://www.elitesparkplugs.com/images/IMG_1079.JPG
http://www.elitesparkplugs.com/images/IMG_1088.JPG
Old Jun 23, 2005 | 12:22 AM
gibbylt1's Avatar
Wow, I wish I would've gotten those wires...for now my dad made a little heat sheild out of sheet metal that hangs off the wire on the side where it's near the primary. We'll see how that goes.
Old Jun 23, 2005 | 12:44 AM
blind527's Avatar
Man those black wires look killer, looks like I'll be gettin those tomorrow
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
