Building Valvetrain!.. How does she look?
Old Jun 22, 2005 | 06:21 PM
96trans am's Avatar
My mods are-
Most all of the bolt-ons.
12 bolt w/4:11 gears.
Longtubes with offroad y-pipe.
Stock Heads
Stock Bottom end
Help me out with this valvetrain
Comp Cams Pro Magnum 1.6 RR non self aligning
Comp Cams Rocker Arm Studs, 7/16
Chromoly 7.2 pushrods (what ones?)
Pushrod Guideplates (what ones?)
Comp Cams 26918 Valve Springs
Comp Cams Steel Valve Retainers
Comp Cams 11/32 7-degree machine locks
OE Hydraulic replacement lifters
Still trying to decide on the cam. These are the cams i am considering
Comp Cams "Extreme" 230/236, .510/.530 112LSA
From cmotorsports.com (custom cams)
227/233, .560/.569 w/1.6RR 111LSA
230/236, .544/.555 w/1.6RR 112LSA
233/239, .569/.577 w/1.6RR 112LSA
Old Jun 22, 2005 | 08:09 PM
snakeatinZ's Avatar
Re: Building Valvetrain!.. How does she look?
[QUOTE=
233/239, .569/.577 w/1.6RR 112LSA[/QUOTE]
dont be a puss go extreame!!!
Old Jun 22, 2005 | 08:13 PM
turbo_Z's Avatar
For the cam Id go with the one with the most lift... thats if you are dead set on going with one of those cams. SStrokerAce makes custom cams and has seen 360 rwhp out of stock heads and his cam... doesnt get any better than that.
And the pushrods.. comp is good.
guideplates... ONLY go with the GM version for the LT1.
Old Jun 22, 2005 | 08:58 PM
96trans am's Avatar
These are not my only options but this is what i came up with after about a month of searching. Not to easy to find a good custom cam. I am actually looking for someone who can help me out and come up with a custom grind cam for me. Ive talked to many different people and places but noone that i am really happy with. Been trying to get a hold of Joe Overton but no luck. Anyone have any suggestions?
Old Jun 22, 2005 | 09:08 PM
Buttercup's Avatar
I've seen a broken rocker arm stud from two different sets of Comp Cams studs. I'd recommend spending a couple bucks extra for the ARP's.
For the guideplates on an LT1 head you need 8 GM p/n 14011051 These have the correct spacing, unlike the standard SBC guideplates. Your other option is to get Isky adjustable guideplates but that is more work and cost for nothing gained.
Much of the valvetrain is going to depend on what cam you decide on. If you plan on a higher RPM power peak, lighter/stronger components will be preferred. For most mild builds such as yours, the regular $37 hardened pushrods will do just fine but the proper springs and light retainers is great.
Does CMotorsports still offer cam kits? If they do, you can save some bucks and get everything packaged together.
Intended use and tranny used might be a good thing to know when asking for cam recommendations.
Old Jun 22, 2005 | 09:15 PM
96trans am's Avatar
No, the last time i looked at their kits, it said they were coming soon. How are the springs I have listed for my valvetrain? Pretty good?
Old Jun 22, 2005 | 11:07 PM
TruDualed95Z's Avatar
Maybe Im off, but with high revving cams like that wouldn't you want some comp r lifters instead of stock replacements?
Old Jun 23, 2005 | 05:36 AM
96trans am's Avatar
I had someone else say the same exact thing. But 3 respected guys said to go with Comp Cams OEM style lifters. As the Comp "R" lifters are hard to adjust. One of them told me they(OEM style) can handle revs at 7500rpm no problem.
Old Jun 23, 2005 | 08:25 AM
CreatiVe2's Avatar
just checked a few days ago, and they were up and running with their cam packages
and also have you ever thought about the Lloyd elliot packages?
www.eportworks.com
Old Jun 23, 2005 | 03:44 PM
96trans am's Avatar
Thanks for checking that out for me man. Yeah ive looked on there but theres a lot of stuff i am buying so heads is not in the budget. Can Lloyd grind me a cam? I been trying to get a hold of Joe Overton but that seems near impossible.
Old Jun 23, 2005 | 06:22 PM
CreatiVe2's Avatar
If you e-mail lloyd i am sure he can set you up with a cam tailored for your setup/needs
Old Jun 23, 2005 | 06:24 PM
I believe Lloyd's cams are only available with the matching heads, not separately.
Old Jun 23, 2005 | 06:25 PM
CreatiVe2's Avatar
that May be the case now, i am not sure, but i do remember his cams being sold seperatly at one point in time
Old Jun 23, 2005 | 06:27 PM
Really? I don't...
Old Jun 23, 2005 | 06:30 PM
CreatiVe2's Avatar
Originally Posted by TruDualed95Z
Really? I don't...
whatever... im just tryign to help the guy out, if im wrong... im wrong...
