LTCC Help Needed (3 red flashes)
Old Jun 24, 2005 | 11:24 AM
sean-k94z's Avatar
Hi everyone,
I installed my LTCC on my new engine and it seems to run ok, but I'm getting 3 red flashes from the LTCC box. I did a search and tried other peoples remedies(took the belt of the alternator, tested grounds), but I can't seem to get the red light to go out. Bob is on vacation for a couple of weeks. Any input would be appreciated.
Thanks,
Sean
Old Jun 25, 2005 | 09:38 AM
drivefast4fun's Avatar
Re: LTCC Help Needed (3 red flashes)
I know this sounds dumb, but when my buddy had this issue on his turbo car, it turned out to be that he had the 1-3-5-7, 2-4-6-8 sides of the thing turned around, so make sure you don't have them switched. Also, Bob said that the white wire is most likely the culprit. Hope this helps?
Old Jun 25, 2005 | 05:40 PM
sean-k94z's Avatar
I'll check it out, my car didnt have a white wire, so I connected it to the solid yellow wire.
Old Jun 27, 2005 | 01:50 AM
sean-k94z's Avatar
The problem seems to be intermittent. I'll check the LTCC box and I'll see a green light, and other times I'll see three flashes. I think I'll shield the opti signal wires and see if that helps.
Old Jul 11, 2005 | 05:12 PM
sean-k94z's Avatar
I fixed it by shielding the OPTI signal wires with aluminum foil and then grounding the foil shield. The wire/foil fit inside the loom, so it looks clean. Something in the car must be RF noisy. Works well now
DirtyDaveW
Dec 1, 2016 05:37 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Collector Car
Dec 17, 2014 01:12 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
