Coolant Leak Passenger side, leaking on starter
Old Jun 26, 2005 | 03:03 PM
SLeeper94Z's Avatar
I devloped a coolant leak its leaking , onto my starter and running down my tranny onto the ground can anyone tell me where this is coming from Im gonna get the system pressure tested tommorow, can anyone help
Old Jun 26, 2005 | 05:21 PM
2 z28s's Avatar
Re: Coolant Leak Passenger side, leaking on starter
the same thing happened on my yukon, its probably the freeze plug(thats what mine was). just drop the starter and look to see if craked, missing or crooked.
Old Jun 26, 2005 | 05:43 PM
SUTTERERMAN85's Avatar
prob freeze plug but could be the coolant lines on the back of the head and it running down the back and ontop of the starter. check freeze plug first
Old Jun 26, 2005 | 06:29 PM
97silvermaro's Avatar
i had the same problem... unbolted the tranny to check the freeze plugs. turns out it was a head bolt that had come loose. tightened it up and havent had any probs since
Old Jun 27, 2005 | 09:33 AM
OBE1 95Z28's Avatar
Your heater lines run just about the starter also.
alex5366
Feb 17, 2015 10:43 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
