question for le2 cam owners
Old Jun 22, 2005 | 04:46 PM
97silvermaro's Avatar
installed le2 cam with le3 heads.... brakes suck (wont even hold the car still to do a burnout) i have a 4l60e with a b&m holeshot 3000... i put on a vacuum canister and the brakes havent changed any??? any ideas? thanks
Old Jun 22, 2005 | 04:49 PM
97s10ondubs's Avatar
Re: question for le2 cam owners
? mine worked fine, and i had like 14" of vacuum when i checked it, sure you dont have a leak?
Old Jun 22, 2005 | 04:59 PM
im gonna hook the guage up tomorrow, but if i do have a leak how do i go about finding it?
Old Jun 22, 2005 | 11:13 PM
1982z28with18s's Avatar
Use a guage and see how much you have, mine weren't the greatest but they worked good enough to drive it daily without a canister.
Old Jun 22, 2005 | 11:23 PM
Kryckter's Avatar
Yeah, I would check everything to make sure you dont have a leak and all your brake components are working properly...My LE2 cam and brakes work great!!!
Joseph
Old Jun 22, 2005 | 11:34 PM
showinoff's Avatar
to find the leak (assuming you have one) get a can of carburator cleaner and start spraying in short bursts around your vacuum hoses/lines and connections. (while car is running) when Idle changes you have found it.
Billy D.
Old Jun 23, 2005 | 01:03 AM
thanks guys
Old Jun 23, 2005 | 11:06 AM
guage read 5" at idle, but as soon as i touched the gas it jumped to 15" then around 2500 rpm it read 20".... this sound like timing?
Old Jun 23, 2005 | 12:18 PM
chevy1963's Avatar
Whats the lift on your LE2 cam? I'm having some vaccum issues two and I have a 306. Where did you hook up the vaccum gauge to measure this?
Old Jun 23, 2005 | 12:35 PM
SStrokerAce's Avatar
Lift doesn't have anything to do with it.....
I would check for a vacuum leak as well, that sounds like the culprit.
Bret
Old Jun 23, 2005 | 12:43 PM
chevy1963's Avatar
I was just asking to see if his cam was as big as mine. I knew it has nothingto do with it. I'm getting a map reading of 65 kpa's @ idle according to datamaster
Old Jun 23, 2005 | 05:17 PM
BIG leak, mine was 13-15 at idle
Old Jun 25, 2005 | 12:24 AM
no leak... just went to the dyno and have very weak compression... thinkin bent valves
mikey4play
Mar 15, 2015 11:45 AM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
