slp fan switch stoped working
Old Jun 22, 2005 | 08:45 PM
2 z28s's Avatar
i bought my 95z28 with an slp fan switch and worked for about 6 months an now it doesnt im assuming its a loose connection. anyone know where it is wired into? i also have a low coolant light on but ny coolant level is fine. any ideas?
Old Jun 22, 2005 | 10:11 PM
Re: slp fan switch stoped working
The fan switch should be plugged in at one of the connectors on the RH shock tower.
The low coolant sensors are a common problem. You can clean it and see if that takes care of it or replace it. If you unplug it, the light will go off, but the level will no longer be monitored.
Old Jun 23, 2005 | 01:18 AM
Dave '97 Z28 M6's Avatar
One of the wire connections on my SLP switch broke after a little bit of use, so I re-soldered it. Check the wires on the switch itself.
Are the fans coming on automatically, without the switch?
Old Jun 23, 2005 | 10:08 PM
2 z28s's Avatar
the fans are still coming on automatically
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
slothgrant
Aug 22, 2002 03:01 PM
