Car quits then restarts - help with codes please
Old Jun 21, 2005 | 05:05 PM
ukfirehawk's Avatar
First run at the strip on Sunday the car stuttered in 3rd gear and brought the SES lamp on. On the return road the motor just faded out and would not start - I've recently replaced the water pump so immediately suspected the opti! - I left the car for an hour or so and on returning it fired first time and has run fine since. - I've just checked the DTC's with the following codes logged.
32 - this is always there - I'm not worried about the EGR system, I think this is something to do with having headers.
33 - 36 - 42 - 48 were also logged. I've yet to clear the PCM and would welcome any suggestions as to the relevance of these codes. I suspect an electrical malfuinction, the starter would occasionally not catch and the time clock added 5 hours to the display .
Thanks in advance.
Old Jun 21, 2005 | 05:17 PM
MAGIC Z's Avatar
Re: Car quits then restarts - help with codes please
33 CODE IS manifold pressure check your hoses from the map sesour and connections at your ecm/pcm 36 distributor high pulse or multi low resolutions 42 ignition control circuit check you wiring between your ignition module and ecm/pcm 48 maf sensor check your wiring between your maf and ecm hope that helps ya
MadMav
Feb 6, 2015 11:02 PM
fpete1992
Dec 11, 2014 03:51 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
