ZEX kit or Predator programmer
Old Jun 25, 2005 | 04:45 PM
baddboy1705's Avatar
Question ZEX kit or Predator programmer
Help!
1996 Z28 which is pretty much stock except for a few minor bolt-ons. I would like to get into the 13's with my car the way it is, my best time os a 14.00 with a miss on #5 cylinder. (GO ME) but I got the miss taken care of and my car runs great. I would really like to put some juice on my motor, but a couple of people told me that I should get a programmer(hypertech, predator) before I do anything so I can retard my timing and adjust my air to fuel ratio and things like that. I planned on getting the programmer later on, but for the time being I was going to go with a ZEX wet or dry system. Any ideas would be great! I just need to get into the mid 13's!
thanks fellas,
-Jeremiah
Baddboy1705@aol.com
Old Jun 25, 2005 | 06:07 PM
91RSLT1's Avatar
Re: ZEX kit or Predator programmer
Hypertech programmer advances timing and leans the car out both of which is BAD on the juice. I would suggest looking around in N2O tech for specs. But basically you need a igition box that can pull timing such as msd digitial 6 or a great alternative is the mallory vii, and then you will need colder plugs, window switch, a heathly fuel pump, a FPSS, etc. As far as the A/F you can tweak that via the jetting. Oh and the juice enough to get into the mid 13's, no sweat. Enjoy the dope.
Old Jun 26, 2005 | 01:37 PM
Robbie's Avatar
I've enjoyed my Zex dry kit since the day I recieved it a little over a year ago. Comes with a booster fuel pump that you add somewhere on your fuel line and all the silenoids you need to get it working. I have some nice kills that otherwise I would have gotten smoked.
Old Jun 26, 2005 | 02:01 PM
Jameslt1TA's Avatar
DO NOT BUY A PROGRAMMER. they are a complete waste of money in my opinion. Try www.madz28.com for great tuning. He can tune you comp and that with some boltons like headers, cai and a good exhaust system ect... should put you in the mid to low 13s with good traction you could maybe even hit a high 12. O ya and i would also look into getting some 3.73 gears, they will wake your car up a bunch also.
Old Jun 26, 2005 | 03:32 PM
96capricemgr's Avatar
Yeah custom tuning is actually also much cheaper than Hypercrap or Predator not to mention better. Using an ignition box for the timing retard is also better than using a tuner because it allows you to not compromise NA power with the lesser timing needed for juice.
madz28.com is good as is pcmforless.com I would think that they have to be the hands down most popular tuners for this board.
Old Jun 26, 2005 | 04:42 PM
thanks for all the replies fellas!
-Jeremiah
Baddboy1705@aol.com
Old Jun 27, 2005 | 05:37 PM
Thumbs up Re: ZEX kit or Predator programmer
one more question, I was also thinking about a new set of gears just to get me closer to the 13's.... anyone think it is possible with a set of gears that are not "overkill" considering I drive the car almost everyday... 3.73's sound good? I have no clue what to run and im not going to take advice from my friends who all drive mustangs...
-Jeremiah
Baddboy1705@aol.com
Old Jun 27, 2005 | 07:46 PM
matt65's Avatar
I agree, MadZ28 has almost put all the programmer mfg. out of bussiness anyway!
Time for new friends...
Old Jun 27, 2005 | 09:26 PM
I have seen that site before but Im not too keen on how it works... Do I just order a reprogramed PCM? or do i have to take the one in my car now and send it. Also is there any way I can have one custom programed for what I want my car to do? or does this company just make them by the thousands and you choose which one you'd like...
Old Jun 27, 2005 | 09:28 PM
o and as far as my friends with the mustangs... haha Im the fastest out of the group and I have the least done to my car... they dont talk much *hit to me but I dont want them giving me the wrong advice just so they can show me up on the track one day...(which will never happen)
-Jeremiah
Baddboy1705@aol.com
Old Jun 27, 2005 | 11:27 PM
matt65's Avatar
You can either send yours in for tuning ....or order one to swap out and send your factory unit back if you would like money for it. Takes about 10 min tops to swap the pcms out. These are definately not made by the thousands. (even though over the years he may have sold a thousand the programming is setup for the options on your car) It is setup for your car: Manual or Auto, and what mods that you have done from boltons to cams to whatever. He can also adjust for emissions bs, gear ratios auto trans options ...just about anythign you can think of that the pcm controls. This is the cheapest route that you can go and one of the highest hp/$$ ratios that you will find.
Look around his site he's one of the best guys you can ever hope to deal with and his product speaks for itself. I couldn't be happier with mine. Our satisfaction is his best advertisement.
http://www.madz28.com/faq.php
Old Jun 29, 2005 | 08:55 PM
-Jeremiah
Baddboy1705@aol.com
I don't know all the Camaro details so maybe there is a clue here and I just missed it but what tranny?
If a t-56 4.10s all the way the .50 OD will tame them wonderfully. If an A4 then 3.42s are nice but most go with 3.73s.
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
Jlo
Jul 22, 2015 05:00 PM
CARiD
Jul 7, 2015 08:19 AM
