dyno results; want to make it to 300 rwhp
Old Jun 22, 2005 | 09:18 PM
seawolf06's Avatar
Here's the dyno results on my newly aquired 95 Z. I wanted to see what you guys thought about not only the power, but what could be making it jump all over the place like that. the only problem i know of is a fouled O2 sensor. There was also a good bit of black smoke out the tail pipes when he stomped on it. I'll be changing the plugs, fuel filter and probably run a fuel system cleaner through it. Just wanted to get some feedback. thanks.
Dyno Results
Old Jun 22, 2005 | 10:29 PM
stereomandan's Avatar
Re: dyno results; want to make it to 300 rwhp
The knock module can make that happen, I think. Madwolf could answer that better. Do you have a LT4 knock module? If you don't, it's worth the $25.
1.6 RR's will get you another 10-15 rwhp. They made a big difference on my car with similar mods as yours.
Dan
Old Jun 23, 2005 | 02:27 PM
seawolf06's Avatar
why did you choose the comp cam pro magnums? How do they compare to Crane? Did you change the springs and pushrods too? How do these affect gas mileage? Where did you get your LT4 KM? Thanks.
Old Jun 23, 2005 | 02:31 PM
Bow94z's Avatar
Search for Jason cromer on the board...he has good prices..
or call the number for parts on this site www.samtaylorbuick.com and ask for jason cromer
Old Jun 23, 2005 | 03:32 PM
Compstall's Avatar
I hit 296 at the wheels last time I dyno'd. I also dyno'd the roller rockers and springs by themselves and gained 7 hp / 2 lbs torque.
Old Jun 23, 2005 | 04:08 PM
seawolf06's Avatar
Brent, I've seen your site several times. I like your ride. Thats about what I'm looking for. What kind of gas mileage do you get with the RR's and that cam? This is my daily driver, so i need to keep it in the mid teens or higher. Thanks.
Old Jun 23, 2005 | 05:55 PM
slomarao's Avatar
rockers,ele. waterpump, no cat(don't know if you do or not), and a real good tune up. I would do the things you listed and change the pcv,coolant, clean maf,tb,air filter
Old Jun 23, 2005 | 06:03 PM
Black1995Z's Avatar
worn cap & rotor kit made mine do that
Old Jun 23, 2005 | 06:11 PM
seawolf06's Avatar
did you replace the cap and rotor with GM parts, or did you upgrade to something else? what's recommended?
Old Jun 24, 2005 | 12:05 AM
Compstall's Avatar
Can't recall the MPG I got before/after. But I did drive from Albuquerque to Wichita Falls, TX and back twice last summer and pulled in almost 28 mpg. I got about 15 or so in town. I haven't really tracked it since I put the cam in a month ago, but I think I only lost about 1 mpg in town.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97 RedSS
Jun 10, 2003 07:58 PM
