help!! How coolant light!!
Old Jun 24, 2005 | 12:06 AM
LUDA0840's Avatar
Angry help!! How coolant light!!
The low coolant light came on about 2 days ago, the coolant level is fine. What might have triggered this light and what can I do to turn it off?
Old Jun 24, 2005 | 12:09 AM
sssalah's Avatar
Re: help!! How coolant light!!
Low coolant sensor on the radiator went bad. Its about 3-4" bellow the fill cap.
Old Jun 24, 2005 | 12:11 AM
LUDA0840's Avatar
oh ok I thoughtthe radiator got clogged and stuff! I even fluhed everything out today just to make sure. About how much is that sensor?
Old Jun 24, 2005 | 12:26 AM
golfer2410's Avatar
i had the same problem a few months ago. my low coolant light would come on and off, so i had my coolant flushed, but it still did it. the coolant level was fine. then i blew a head gasket, got the head gasket fixed. now my light hasnt come on since. it was weird. i think that i just must have had a slow leak through the head gasket, then it just blew one day. not fun at all, so i would be careful about just replacing the sensor.
Old Jun 24, 2005 | 12:56 AM
sssalah's Avatar
If you're sure the coolant level isn't low then just disconnect the sensor wire, if the light turns off then it's the sensor for sure.
Part number is 10096163, check it out here:
http://www.gmpartsdirect.com/results.cfm
Old Jun 24, 2005 | 12:50 PM
mattybz28's Avatar
If someone else did the work on your car they could of just unplugged the sensor their selves... might wanna check on that.
Old Jun 24, 2005 | 03:14 PM
CamaroZ2894's Avatar
luda bring it by the house and ill unplug it for ya.
Old Jun 24, 2005 | 05:56 PM
LUDA0840's Avatar
did it yea its the sensor, ill just disconnect the wire since i refilled everything already.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:50 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
