View Full Version : LT1 Based Engine Tech
- Who has the meanest sounding LT1
- Weird problem with headlight motor?
- Two Codes Thrown
- Water in Oil......
- help please walbro fuel pump
- Which would be louder on a 95 LT1 Z28?
- Pin in hotcam, how to drive it in more?
- wiring question
- WTF pt. II: Car shut off when driving
- Best LT1 Cam
- ABS intermittent working
- What are some Cheap/Free mods for an LT1?
- ZZ409 Cam Sound Files
- best water pump?
- Oil Pan Leaking Problems-Canton Pan
- Stud Girdle and Tall Valve Cover Question
- Trans Mount Bolt, What size thread? Anyone
- Surging and hesitation fixed
- GAH! My times leave alot to be desired, fellas come in please
- LS1 brake conversion question...
- new stock coil, how much better is performance coil
- GM 847 question
- Safely spin to 6200 RPM
- Who is cheapest for T56 rebuild parts?
- #2 spark plug
- I am stumped
- Vats bypass
- windshield wiper question
- console & glove box light info
- LT1 edit!
- Anyone have dynojet files?
- starter burned up
- Front Suspension 101...
- Cranks but won't start....
- ok guys..please help!!huge backfire probelms, barely runs
- sensor on back of block?
- Timing chain sets???
- how to install pro 5.0
- Vavle Cover Bolts, What size are they?
- need good header gaskets
- TB Bypass supplies.
- hpp3 help please
- 94-95 macs vs 96-97 macs
- A few "noob" LT1 questions...
- flp owners
- Hey Hot Cam guys....in here
- Stock injector and TB size
- cams or headers?
- Starts fine, Then it doesn't??
- Cheapest place to get opti??
- Copper Spark Plugs.
- 95 Z28 Camaro spark plugs & wires
- Wiring up an A/F gauge??
- whats the fastest youve gone with macs
- tdc valve adjust
- Water line hose that goes to heater core
- Fuel Pressure
- Speedo Recalibration Question???
- Assistance w/pushrods & valvetrain components...
- mac header question
- Question on a Code
- Removing Traction Conrol
- Is my car running right?
- LT1 Block Question..
- ****ing misfire
- 1Le elbow where to buy???
- Mandrel Bent Tubing
- lt4 rockers in an lt1
- Need help finding a tuning place
- locking fastners
- Z Rated or Not Yokohamas?
- Water pump gaskets?
- Shift kit
- oil pressure?
- O2 Sims.
- Need help....nothing but problems
- My car's get up and go, got up and went!
- Front bumper support removal...
- hurst roll control
- Need immediate help with my shifter, not right gear
- Bad lifter already?
- streetmaster suspension???
- 1LE Results....
- Best Customer Service Expierence, Ever!
- throttle return spring Q
- How does the Walmart do it yourself a/c kit work?
- Bringing my 96 LT1 M6 to the track today! First time! need some tips!
- Torque converter lockup switch install guide inside...
- Water seeping in where glass meets hatch
- Missing/hesitation problem on 93Z?? Not opti
- Where is that place with cheap bilstein shocks ?
- Lighter replacement Rad fans?
- Where does a waterpump leak from?
- those with svo injectors, HELP!
- Waterpump Install help
- Do you have to use new brakes, when putting on new rotors?
- Help taking out my fuel pump!!
- Battery/Alternator/Electrical problem arlington, tx
- reduce timing help for over heating.
- Dissapointing dyno results - Questions
- overheating --have changed many parts -- please help!
- Head Light Conversion
- *How to page* for lowering springs?
- Leaded race gas mixed w/ pump 93??
- what stall converter is recommended for the lt4 hot cam?
- Hood sleeve/Hood bra- where get it
- Uh oh... Is it time?
- What is the factory stall speed in a 95 Z?
- lug cap part #
- LT4 conversion package
- Question on fan blower motor?
- Question on gear noise?
- EGR Blockoff Plate Dimensions
- LT1 or LS1 (which is better)
- help me confirm my bad lifter theory
- HELP!! Missing on 2 4 6 8
- hesitating after cam installed...
- Difficulty starting, any suggestions?
- Looking at a 95 TA, need advice about previous maintenence
- PCM for less worth it on a six speed?
- help me solve my spark problem. *PICS*
- Barry White of exhaust?
- combination valve for brakes
- ECM shot? How to tell?
- Running hot at idle, need help please.
- wiper blades overextend
- K guys......lets go... SYNTHETIC or Regular Oil?????
- Had to do it :(
- Just installed LT4 balancer on my LT1 but didn't see arrow, is this a concern??
- Can anyone tell me what parts to buy when installing a cam??
- Is getting rid of theMAF screen good or bad?
- Am I going to have any problems using the HPP3 with ported/descreened MAF?
- Can someone explain head/valvetrain specs to me???
- Stock headed 383 or TEA 355?
- Custom Headers
- need help asap?
- Good All Season Tire Choice?
- Buying new tires can't decide between firestone firehawks.......
- ignition coil
- macs vs slp shorties?
- What the?
- gas guage :(
- PH. # for PCMsforless
- Speedo change for '93 (Dakota Digital)?
- When to replace O2 sensors?
- Real Lt1 To Lt4 Conversion - Wtf?
- aluminum driveshaft?
- Having a few problems and need some help.
- water wetter makes the car cool down with 50/50??
- does anyone have any problems removing the plugs with the hooker long tubes
- front swaybar
- Zr1 rims getting stuck on the axle
- Rear End Goes Kapoot!
- Cig lighter?
- Question bout transmissions
- Driver Side Window Loose
- Aftermarket torque converter question.
- valve lash setting...
- 1.6rr? what all do you need??
- t-top conversion?
- coolant temp. rising when the AC's on
- Car running really bad, strangest DATAMASTER file inside
- running HOT!!!
- Scanmaster repair
- Really goofy spark lines
- optispark to LS1 ignition conversion
- What kind of power should I expect?
- Which is better and why? Stock LT4 or ported LT1 heads
- Bolt size needed please
- Engine possibilities?
- Heads flowed, valves in or out?
- How does this cam look?
- should i trade it in?
- Guesstimated 1/8 mi ET's?
- quick question
- LT4 conversion? how much HP?
- LT1 Hesitation/cutting out
- Is this a bad rocker arm bolt?
- PCMforless or Ed Wright
- How is our battery secured in the engine bay? going to a track in the next week
- Poser for the day???
- Gear change question
- Symptoms of Weak Valve Spring
- Need facts on LT1, 4 purchase
- people with longtubes please step inside
- Need to know what a spyder is? It has to do with seals ?
- Best tranny fluid for a 700R4/4L60E?
- SLP Products
- Finished A/C delete
- Combination Motorsports
- Guys with OBDII and cams...where are you going for tunning?
- my throttle response sucks
- new pcm
- Free Mods
- Need pics of your homemade LT1 CAI..
- ignition / coil upgrade
- Question about Waterpump. Been sitting for awhile and its hard to turn.
- going quick with manifolds
- Top end rebuild... Need some help.
- How much HP from 355
- What else could it be....losing coolant :(
- Holy smoke - New found power with Lloyd's heads!
- Engine mounts
- Need Help Selecting Camshaft for 383
- coil problem?
- Universal Plug wires
- Just finished intake man. install, wheres this hose go?
- Thanks to all for helping me find my short
- Do I need the install kit to fit on the loudmouth?
- Honda ATF is really good.
- crankshaft pulley???? NEED HELP!!!!!!!!!!!!
- Another roller rocker ?
- LT4 conversion?
- Which stroker parts for NA CC306
- What would strenghten my body more?
- Could soemone please tell me exactly what is back pressure?
- Head and Cam time! Help me make a comprehensive list of parts!
- best Intake Elbows
- ZR-1" on Z-28?
- What is the most ci an lt1 can be?
- Need Help With Car Asap!!!!!!
- Fireworks unger Hood
- Loose Catback?
- Alternator Bracket pics, Dont know what bolts go where.
- 1.6 rollor rocker on stock motor
- best exhaust for a 95
- Really basic Ignition Coil Wiring...
- More XE cam dyno results.
- Fuel Guage problem
- Plug Wires
- Two thumbs and a big toe up for PCMforless!
- Both Power Windows Quit Working After Car Wash???
- Programming the key fob to car
- vibration after header install
- What should my car be shifting at?
- What causes an SES light while driving for more than 5mins in 6th gear?
- Which LCA's are for me?
- Help: Front Bottoming Out? Air Dam Scraping!
- rears brakes rubbing...quick help
- Need Urgent Help, Transmission Going Crazy
- T-Top weather stripping
- LT1 Picture...
- Need help
- How can you tell if you have a misfire?
- How come everyone with true duels have turn downs?
- Help on GEAR install
- need help on coolant lines from heads to TB
- new block
- What best converter for mostly stock?
