running HOT!!!
running HOT!!!
recently had LT1 edit installed....
programmed the fans to come on at 180 and i havent put the new t-stat in yet but its running really hot, i cant even go down the block without it red lining...so im not even driving it right now...
is it LT1 edit or just the t-stat?
Originally posted by Gripenfelter
Are you adding a 160 stat or a 180 stat?
If you emptied your rad at all you might have air trapped in your system.
You'll have to bleed it out using the two bleeder screws.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
