combination valve for brakes
Old Aug 29, 2003 | 08:04 AM
predator's Avatar
does anyone have a part number for the combination valve for the brakes or know best place to get one (mine leaks)
Old Aug 29, 2003 | 09:39 AM
GM PART # 18020589
It's over $135 wholesale.
You might just try a seal/bolt kit :
GM PART # 18019492 (~$10 wholesale)
I guess it depends on where it is leaking. You might just have a messed up fitting.
Old Aug 29, 2003 | 09:42 AM
predator's Avatar
ouch it is leaking from the top where the lines go in the rear line is leaking because my rear brakes went out i had to refill and bleed it has a real slow leak probably takes 6 month or so to drain the rear split out but it done it
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
