Speedo Recalibration Question???
Old Aug 29, 2003 | 10:26 PM
Blue96z28's Avatar
I recently installed 3.42's and I wanted to know my options on recalibrated the speedometer. My local dealer wants over 60 dollars just to program it, which is crazy. Where all can I get it done, or with what equip do I need to do if myself?
Old Aug 29, 2003 | 10:39 PM
JoeliusZ28's Avatar
I have yet to do this so im no expert... but I know you can do it yourself with: A Computer, a special link cable (going from the comp to the OBDII connector under the dash), and some pcm programming software for the computer.
Old Aug 29, 2003 | 10:41 PM
JoeliusZ28's Avatar
....maybe I shouldve mentioned: that cable you need is almost as much money as having the dealer do it
Old Aug 30, 2003 | 04:16 PM
Blue96z28's Avatar
that sux.....can anyone give me some more info? Is it just the cable that you have to buy? Is the software free? Where can I buy this stuff at? TTT please
Old Aug 30, 2003 | 05:42 PM
Cmr0z28's Avatar
your best options are to either
1. find a used hypertech power programmer for ~150
2. let the dealer do it
3. take advantage of the situation and get a custom tune from www.madz28.com or www.pcmforless.com
LT1 edit is $550.....but it comes with the cable which is $100
Old Aug 31, 2003 | 03:51 PM
Blue96z28's Avatar
I've talked to my local dealer, and they want almost 70 dollars just to recalibrate it, I know this is BS as it only takes about 15 seconds and requires no physical labor what so ever.
I would'nt mind even paying 100 or 125 if it was for a program like lt1 edit or something where I could hook my laptop up to my car and change settinging and I could get a way to read engine codes as well.
Does anyone know of any do-it-yourself programs that will let my check codes and change engine settings as well as recalibrate my speedometer for under or around 120 dollars?
mschmidt33
Mar 15, 2015 07:20 PM
blac94Z
Feb 10, 2015 11:02 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Jul 4, 2005 05:00 PM
Nostang 96z
Aug 31, 2002 12:01 PM
