does anyone have any problems removing the plugs with the hooker long tubes
Old Aug 28, 2003 | 07:53 PM
mehoffz24's Avatar
i was just wonderin because i need to get rid of the edelbrocks for something else. thanks for the input
Old Aug 28, 2003 | 08:00 PM
funina91ss's Avatar
Drivers side is a cake walk the pass. side is a little harder the two back ones you have to get from under the car and they can be tricky to get started.. but well worth it IMO>>
Old Aug 28, 2003 | 08:19 PM
Camaro37's Avatar
Took me 20 min. to change 6 spark plugs with LTs but the last 2 back pass. ones took a good 3 hours. I was having all kinds of problems.
Old Aug 28, 2003 | 08:22 PM
EviLZ28's Avatar
Is it any easier if you have a BMR k-member?
Old Aug 28, 2003 | 08:31 PM
funina91ss's Avatar
It probally take around 1.5-2.5 hours to change the plugs depending on how well you can work on your car.I can change them in less than an hour but I have done it a few times. Having a BMR K-Member might help a little but the K-member is not in the way that much. I dont know how many guy do it this way but I just use a 5/8" spark pulg socket and a 3/4" open end wrench to change my plugs. And always use never seize on my spark plugs.
mehoffz24's Avatar
what do you mean took 3 hrs. why? im so curious now becasue i have the edelbrock and i cant back the plugs out of the head all the way with out removing the header from the head. this is an issue on both sides, not so bad tho on the drive side. thanks for the fast responses, please tell more!!!
Old Aug 28, 2003 | 10:21 PM
john96ws6's Avatar
The only ones that are difficult to get at are the back 2 on the passengers side. It just takes a little time (NOT 3 hours) to get your hand in there. It really isnt THAT hard. I love the plug access, but then again I have skinny hands.
Old Aug 28, 2003 | 11:50 PM
OBDIICamaro's Avatar
You should have the first 6 pulled in about 5 minutes and the back 2 in about 5 minutes.
Buy or make the custom Spark plug tool with one side cut off for easy access.
Old Aug 29, 2003 | 12:16 AM
Camaro37's Avatar
It took me so long because there isn't a whole lot of room to fit a socket and wrench, ratchet, or anything in there. Some people have a smaller plug socket that they use but I don't, I'm sure it would have helped alot. What took the most time was getting the plug in; it kept cross-threading and the few times I got it in straight the socket wouldn't come off the plug. I also got very frustrated which didn't help anything.
Old Aug 29, 2003 | 12:31 AM
speedmiser's Avatar
I went from Edelbrock shorties to Hookder long tubes. The Edelbrocks were such a pain in the a$$, I just cut the tubes off with a sawzall, then removed the flanges from the heads.
Anyway, plug access is soooooo much better . I can change the plugs in 20 minutes easy. Course I have no AC or heater, or the lines, or that stupid box under the hood that used to protrude from the firewall - so there's plenty of room to get to 6 and 8 from the top
Old Aug 29, 2003 | 12:56 AM
tom3's Avatar
if anybody can do them fast, can you post a pic of the tools you use? it takes me lots of time to even get a tool close to the plug; holding the new plug in front of the hole is a challenge a well...
I bought an open wrench that is 'bent' like: ___/-- and it has helped but it still sucks
Old Aug 29, 2003 | 01:06 AM
atljar's Avatar
Drop the starter for #6 and 8.
I can do them all in about 30 min. I made a tool. Took a standard size socket (5/8ths ? forget what they are). Drilled out the place where the ratchet normally attaches so that it can slide over the plug totally. Then welded an old open end wrench the the end of it and bent it a tad. Works like a charm.
Old Aug 29, 2003 | 02:15 AM
illegalactivist's Avatar
plug access is killer with hooker LT's. did mine in no time at all. the back 2 on the passenger side are more difficult, but still easy enuff to do... it takes about as much time to get those 2 off as it does the other 6. plug WIRES are still a pain in the ***... easy up top, but a real bitch down low on the passenger side... but that's gonna be that way no matter what you do.
- jay
Old Aug 29, 2003 | 05:48 AM
Dan Oldham's Avatar
Why don't you market this idea to Craftsman or someone? Unless of course, there's a tool out there that is available like this. I'm sure you could make some serious money off it if it's as good as you say it is.
If you don't market it, I will.
Old Aug 29, 2003 | 06:06 AM
baron4406's Avatar
Just remove the starter like they recommend here, its easy to remove. I can actually reach all the plugs from underneath doing that.
