What would strenghten my body more?
Old Aug 27, 2003 | 08:50 PM
dnz28's Avatar
What would work best 4 point role cage or lcas?
Old Aug 27, 2003 | 09:05 PM
96z's Avatar
96z
4 point cage is a waste IMO. Weighs a ton more than and wont do much more than add an extra 40-50 lbs over subframes. Subframes are way cheaper too.
Josh-'04 GTO's Avatar
I didn't see subframe connectors in your signature. If you wanna stiffen up the chassis, that's the way to go. I good 6 point roll bar can help too, but you'll still want the subframe connectors to tie it all together. LCA won't stiffen the chassis, but will control axle movement better than stock ones.
Old Aug 27, 2003 | 09:33 PM
dnz28's Avatar
Yea I met sub frame connectors but for some reason lcas are on my mind. Sorry about that.
Old Aug 27, 2003 | 11:28 PM
revtime's Avatar
Go with subframes.
If you wanna go really stiff get some Double Diamonds, otherwise BMR makes some nice ones.
Old Aug 27, 2003 | 11:42 PM
Terran2k's Avatar
i dont see how LCA's will stiffen the chassis, they'll fight wheel hop though. Sub-frames will definitely stiffen it up, as well as, a STB, that should also help some.
Old Aug 28, 2003 | 12:36 AM
Compstall's Avatar
Hit the gym, press some weights...
Old Aug 28, 2003 | 01:09 AM
96 WS6's Avatar
steroids
HectorM52
Jul 30, 2017 11:46 AM
mark0006
Apr 21, 2015 12:42 PM
CARiD
Feb 9, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
